06-13-2017 06:04 AM
Hello all
I need to add a auto reply with a text disclaimer
(to indicate to write to a new Email domain)
I try with the incomming mail filtering
It's works with theses Actions :
Add Disclaimer Text
and
change the Rcpt to : $envelopefrom
but the Email is not deliver to the original recipient.
I try to add BCC copy:
Send Copy (Bcc:) bcc ("$envelopesender", "$Subject")
but that dont work, it's doesn't add the disclaimer text ?!
just return the mail to the $envelopefrom with no text disclaimer
Thanks for your help
Lionel D.
06-13-2017 06:44 AM
Hi Lionel,
I would recommend using the notify action instead.
You can create a custom notification template under Text Resources and this action can be used to inform the sender of the change in email domain.
With this the original email would continue without any changes and get delivered to the intended recipient.
Thank You!
Libin Varghese
06-14-2017 02:31 AM
Yes It's Works !
Thanks !
06-14-2017 02:43 AM
Glad it worked.
- Libin V
