06-14-2017 11:36 AM - edited 03-08-2019 10:58 AM
We have a huge discard rates (45%) in all port channels,
ONATTDISTSW01#show int po11 | i Input queue:
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 16209723
ONATTDISTSW01#show int po12 | i Input queue:
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 16543210
ONATTDISTSW01#show int po13 | i Input queue:
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 59358 <-- reset yesterday
ONATTDISTSW01#show int po14 | i Input queue:
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 15475790
ONATTDISTSW01#show int po15 | i Input queue:
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 16199695
ONATTDISTSW01#show int po16 | i Input queue:
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 13906375
ONATTDISTSW01#show int po17 | i Input queue:
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 302878 <-- reset yesterday
Do you have any solution for this
06-14-2017 11:59 AM
do you have output errors too or any other errors under the physical interfaces in the portchannels
what version of ios are you on
what do the physical interfaces look like for drops , are the drops on one or all physical interfaces
06-15-2017 07:13 AM
Do you have output errors too or any other errors under the physical interfaces in the portchannels
yes,
ONATTDISTSW01#show int gigabitEthernet 2/0/42 | i Input queue:
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 392676
GigabitEthernet2/0/42 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 00f8.2c96.9a2a (bia 00f8.2c96.9a2a)
Description: Uplink to ONATTSW01
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:01, output never, output hang never
Last clearing of "show interface" counters 19:12:19
Queueing strategy: fifo
Output queue: 0/2000 (size/max)
5 minute input rate 1000000 bits/sec, 279 packets/sec
5 minute output rate 91000 bits/sec, 14 packets/sec
4184622 packets input, 1645110842 bytes, 0 no buffer
Received 75717 broadcasts (64568 multicasts)
0 watchdog, 64568 multicast, 0 pause input
928998 packets output, 483778653 bytes, 0 underruns
392676 output errors, 0 collisions, 0 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
What version of IOS are you on
Model SW Version SW Image
WS-C3850-48T 03.06.06E cat3k_caa-universalk9
the error is not balanced at the both interfaces
ONATTDISTSW01#show int gigabitEthernet 1/0/42 | i Input queue:
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
06-15-2017 07:30 AM
try change the load balance so it starts using both inks , we use src-dst-port works well but you should have multiple options , first look I would think your over utilizing one side of the po causing it to get hammered resulting in output drops , if you balance the traffic out it may slow down the drops
also as Leo sad are you using qos , it may be worth setting it on the switch , is it a user access switch
Load Balance options
(config)#port-channel load-balance ?
dst-ip Dst IP Addr
dst-mac Dst Mac Addr
dst-mixed-ip-port Dst IP Addr and TCP/UDP Port
dst-port Dst TCP/UDP Port
extended Extended Load Balance Methods
src-dst-ip Src XOR Dst IP Addr
src-dst-mac Src XOR Dst Mac Addr
src-dst-mixed-ip-port Src XOR Dst IP Addr and TCP/UDP Port
src-dst-port Src XOR Dst TCP/UDP Port
src-ip Src IP Addr
src-mac Src Mac Addr
src-mixed-ip-port Src IP Addr and TCP/UDP Port
src-port Src TCP/UDP Port
theres also a similar bug if the output and total counters are incrementing together but looking at your last post there not but maybe something to keep an eye on ,I don't see 3.6.6 in it though
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb65304/?referring_site=bugquickviewclick
06-14-2017 03:41 PM
Check your QoS settings. If it doesn't have any then you'll need one.
06-16-2017 04:01 AM
have a look at this document: Catalyst 3850: Troubleshooting Output drops
On our c3850's we saw also massive drops and increasing the queue-softmax-multiplier worked really well.
Rolf
