Unified Presence 9 Cisco DB Error
Jun 14th, 2017
Hello, after server power loss on Presence pub 9.1.1.41900-1, we have error:
A Cisco DB[STOPPED]  Component is not running
-------------------- utils dbreplication status --------------------
Database is down; please restart the database before reattempting a status check
file view activelog cm/log/informix/ccm.log
23:34:37 IBM Informix Dynamic Server Started.
Wed Jun 14 23:34:38 2017
23:34:38 Event alarms enabled. ALARMPROG = '/usr/local/cm/bin/ccmalarmprogram.sh'
23:34:38 Booting Language <c> from module <>
23:34:38 Loading Module <CNULL>
23:34:38 Booting Language <builtin> from module <>
23:34:38 Loading Module <BUILTINNULL>
23:34:38 SQLTRACE: SQL History Tracing set to 2000 SQL statements.
23:34:44 Waiting 600 seconds for startup to complete.
23:34:44 DR: DRAUTO is 0 (Off)
23:34:44 DR: ENCRYPT_HDR is 0 (HDR encryption Disabled)
options: q=quit, n=next, p=prev, b=begin, e=end (lines 45881 - 45900 of 46102) :
23:34:44 Event notification facility epoll enabled.
23:34:44 IBM Informix Dynamic Server Version 11.50.UC9XD Software Serial Number AAA#B000000
23:34:45 (4) connection rejected - no calls allowed for sqlexec
23:34:45 (5) connection rejected - no calls allowed for sqlexec
23:34:45 (6) connection rejected - no calls allowed for sqlexec
23:34:45 (7) connection rejected - no calls allowed for sqlexec
23:34:45 (8) connection rejected - no calls allowed for sqlexec
23:34:45 (9) connection rejected - no calls allowed for sqlexec
23:34:45 (10) connection rejected - no calls allowed for sqlexec
23:34:45 (11) connection rejected - no calls allowed for sqlexec
23:34:45 (12) connection rejected - no calls allowed for sqlexec
23:34:45 (13) connection rejected - no calls allowed for sqlexec
23:34:45 (14) connection rejected - no calls allowed for sqlexec
23:34:45 (15) connection rejected - no calls allowed for sqlexec
23:34:45 (16) connection rejected - no calls allowed for sqlexec
23:34:45 (17) connection rejected - no calls allowed for sqlexec
23:34:45 (18) connection rejected - no calls allowed for sqlexec
23:34:45 (19) connection rejected - no calls allowed for sqlexec
23:34:45 (20) connection rejected - no calls allowed for sqlexec
23:34:45 (21) connection rejected - no calls allowed for sqlexec
options: q=quit, n=next, p=prev, b=begin, e=end (lines 45901 - 45920 of 46102) :
23:34:45 (22) connection rejected - no calls allowed for sqlexec
23:34:45 (23) connection rejected - no calls allowed for sqlexec
23:34:45 (24) connection rejected - no calls allowed for sqlexec
23:34:45 (25) connection rejected - no calls allowed for sqlexec
23:34:45 (26) connection rejected - no calls allowed for sqlexec
23:34:45 (27) connection rejected - no calls allowed for sqlexec
23:34:45 (28) connection rejected - no calls allowed for sqlexec
23:34:45 (29) connection rejected - no calls allowed for sqlexec
23:34:45 (30) connection rejected - no calls allowed for sqlexec
23:34:45 (31) connection rejected - no calls allowed for sqlexec
23:34:45 (32) connection rejected - no calls allowed for sqlexec
23:34:45 (33) connection rejected - no calls allowed for sqlexec
23:34:45 (34) connection rejected - no calls allowed for sqlexec
23:34:45 (35) connection rejected - no calls allowed for sqlexec
23:34:45 (36) connection rejected - no calls allowed for sqlexec
23:34:45 (37) connection rejected - no calls allowed for sqlexec
23:34:45 (38) connection rejected - no calls allowed for sqlexec
23:34:45 (39) connection rejected - no calls allowed for sqlexec
23:34:45 (40) connection rejected - no calls allowed for sqlexec
23:34:45 (41) connection rejected - no calls allowed for sqlexec
options: q=quit, n=next, p=prev, b=begin, e=end (lines 45921 - 45940 of 46102) :
23:34:46 (42) connection rejected - no calls allowed for sqlexec
23:34:46 IBM Informix Dynamic Server Initialized -- Shared Memory Initialized.
23:34:46 Started 1 B-tree scanners.
23:34:46 B-tree scanner threshold set at 5000.
23:34:46 B-tree scanner range scan size set to -1.
23:34:46 B-tree scanner ALICE mode set to 6.
23:34:46 B-tree scanner index compression level set to med.
23:34:46 Physical Recovery Started at Page (1:7261).
23:34:46 Physical Recovery Complete: 0 Pages Examined, 0 Pages Restored.
23:34:46 Logical Recovery Started.
23:34:46 10 recovery worker threads will be started.
23:34:46 Checkpoint Record not Found in Logical Log.
23:34:47 Cannot Rollforward from Checkpoint.
23:34:48 oninit: Fatal error in shared memory initialization
23:34:48 IBM Informix Dynamic Server Stopped.
What we can do to restore server database?
Jaime Valencia Wed, 06/14/2017 - 17:08
  • Cisco Employee,
  • Hall of Fame,
    2011
You probably want to call TAC for this, or restore your server from a backup.
GlKlondike Thu, 06/15/2017 - 05:45
After recovery disk file-check, have same error
oninit: fatal error in shared memory initializaion
