CUBE setup and Zone Based FW
Not applicable
Hello @ all,
Is there any way to statically specify the media ports used by the RTP stream?
I have the following issue:
A soft phone is registered to CUBE via SIP. On the CUBE router Zone Based Firewall is configured to also allow only defined traffic destined to the router itself (self zone). As a workaround, I have to allow the whole UDP traffic destined to router so that the RTP stream is pass through.
is there any way to define the ports used for RTP manually?
Chris Deren
Yes, you can change RTP ports used by CUBE with following command:
rtp-port range
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_proto/configuration/xe-3s/cube-proto-xe-3s-book/voi-ip6-voip.html#task_39847922DDE9413BAFE73A80EE44EA5D
