06-17-2017 06:40 AM - edited 03-08-2019 11:00 AM
Hi guys,
Sorry if this post is not supposed to be here.
I am inserting X2-10GB-SR to my 6509. How can i know if i should plug in SC/UPC or SC/APC into it?
Thanks!
Solved! Go to Solution.
06-17-2017 01:24 PM
For connecting switches, routers, servers, and all the other network components, you just need regular SC/UPC. APC is used to connecting patch panels together and also for other application like GPS, video, etc.... as it gives you a tighter connection but it will not work on network equipment.
So, just use SC/UPC. Most of the time, it is just simply called SC.
06-17-2017 06:49 AM
X2-10GB-SR
SR means Short Range. This means SC/UPC or SC/APC don't apply because they are meant for LR.
X2 means the patch cable at one end should be SC multi-mode.
06-17-2017 07:08 AM
Hi Leo,
I understand that the patch cord has to be multimode. If SC/APC and SC/UPC are for LR, may i know which is for SR?
06-18-2017 07:01 PM
LR/Single mode cables are "normally" yellow.
SR/Multimode vary - orange, or newer ones are aqua/blue.
If the devices are in the same room, you should have no problems if optical interfaces and cables are all the same kind. However, if you have panels and other intermediate cables, they ALL should be the same end to end (single or multimode). You can't mix and match cable types.
PS - what are you connecting to at the other end? It's device (whether X2 or SFP+) should ALSO be designated SR. You can't interconnect an SR and an LR optical interface.
06-17-2017 07:16 AM
SR stands for "short reach". This means you need multi-mode fiber.
SR=short reach
LR=long reach
06-17-2017 10:05 AM
Hi Reza,
Im aware of SR and LR but patch cords are labelled as SC/UPC or APC. Or did u mean as long as its multimode, it will be fine?
06-17-2017 01:24 PM
