GRE IPV6 Confusion!
Answered Question
Jun 19th, 2017
I need some clarity on this type of GRE  configuration
Configuration of R3:
interface Tunnel34
 no ip address
 ipv6 address 2026::34:1/122
 ipv6 enable
 ipv6 ospf 6 area 34
 tunnel source Serial0/0/0.34
 tunnel destination 10.1.1.10
 tunnel mode ipv6
1. What type of tunnel is this? is it plain old tunnel, and in that case is  in that case is is still necessary to have
tunnel mode ipv6 ?
2. Is it an ipv6 tunnel and the tunnel mode needs to be #tunnel mode ipv6 ?
3. Is it always mandatory to have a tunnel mode ?
4. what is the difference between #tunnel mode gre ipv6
& #tunnel mode ipv6 ?
Thanks in Advance
Correct Answer by Philip D'Ath about 1 month 5 days ago
Correct.
Overall Rating: 5 (1 ratings)
Philip D'Ath Mon, 06/19/2017 - 20:35
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN, LAN, VPN
It is tunnelling IPv6 over IPv4.
lowfell Mon, 06/19/2017 - 21:10
So in this instance is it mandatory to have #tunnel mode ipv6 ?
Philip D'Ath Mon, 06/19/2017 - 21:13
    2017 WAN, LAN, VPN
It has to match the remote end - and it has to be a type that tunnels IPv6.
So you could use a different IPv6 tunnel mode - but you must have one.
lowfell Mon, 06/19/2017 - 21:19
So if its                                                 R1#tunnel mode ipv6
then the other side has to be               R2#tunnel mode ipv6 ?
Or                                                        R1#tunnel mode gre ipv6
                                                            R2#tunnel mode gre ipv6     or whatever as long as they match?
Correct Answer
Philip D'Ath Mon, 06/19/2017 - 21:20
    2017 WAN, LAN, VPN
Correct.
lowfell Mon, 06/19/2017 - 21:27
Thanks Philip. That's much appreciated.
