06-19-2017 10:50 PM
I have following topology
R1----------R2----------R3
R1 is ASR 9000 series router and R3 is ASR 900 router. Both are enabled with segment routing. I created one l2vpn xconnect from R1 to R3 which is not coming up.
Below is the configuration of both the routers
R1#
router ospf 1
router-id 5.5.5.5
segment-routing sr-prefer
segment-routing prefix-sid-map advertise-local
area 0
segment-routing forwarding mpls
mpls traffic-eng
segment-routing mpls
interface Loopback0
prefix-sid index 3
interface TenGigE0/0/2/0
cost 1
network point-to-point
passive disable
fast-reroute per-prefix
fast-reroute per-prefix ti-lfa enable
interface TenGigE0/0/2/2
cost 1
passive disable
mpls traffic-eng router-id Loopback0
l2vpn
pw-class MPLS
encapsulation mpls
ipv4 source 5.5.5.5
xconnect group SR-P2P-1
p2p SR-P2P-1
interface Bundle-Ether100.181
neighbor ipv4 3.3.3.3 pw-id 181
pw-class MPLS
R3#
router ospf 1
router-id 3.3.3.3
segment-routing area 0 mpls
network 3.3.3.3 0.0.0.0 area 0
network 10.10.10.8 0.0.0.1 area 0
network 192.168.12.0 0.0.0.3 area 0
mpls traffic-eng area 0
set-attributes
address-family ipv4
sr-label-preferred
exit-address-family
connected-prefix-sid-map
address-family ipv4
3.3.3.3/32 index 1 range 1
exit-address-family
interface Port-channel22
service instance 181 ethernet
encapsulation dot1q 181
xconnect 5.5.5.5 181 encapsulation mpls
Both routers are configured with segment routing only
R1# sh l2vpn xconnect detail
Group SR-P2P-1, XC SR-P2P-1, state is down; Interworking none
AC: Bundle-Ether100.181, state is up
Type VLAN; Num Ranges: 1
VLAN ranges: [181, 181]
MTU 9188; XC ID 0xa0000005; interworking none
Statistics:
packets: received 0, sent 0
bytes: received 0, sent 0
drops: illegal VLAN 0, illegal length 0
PW: neighbor 3.3.3.3, PW ID 181, state is down ( local ready )
PW class MPLS, XC ID 0xc0000008
Encapsulation MPLS, protocol LDP
Source address 5.5.5.5
PW type Ethernet, control word disabled, interworking none
PW backup disable delay 0 sec
Sequencing not set
PW Status TLV in use
MPLS Local Remote
Label 24042 unknown
Group ID 0x1e0 unknown
Interface Bundle-Ether100.181 unknown
MTU 9188 unknown
Control word disabled unknown
PW type Ethernet unknown
VCCV CV type 0x2 0x0
(none)
(LSP ping verification)
VCCV CC type 0x6 0x0
(none)
(router alert label)
(TTL expiry)
Outgoing Status (PW Status TLV):
Status code: 0x0 (Up) in Notification message
MIB cpwVcIndex: 3221225480
Create time: 19/06/2017 14:24:55 (20:48:10 ago)
Last time status changed: 19/06/2017 14:31:42 (20:41:24 ago)
Error: MTU mismatched
Statistics:
Can anyone help me if I am missing something.
08-16-2017 01:47 PM
I see that there is an MTU mismatch between the two PE routers. Fix that and see if that does it...
