Hi all
Here's the problem... Our primary ACS 5.4 admin node has died. I have tried to promote secondary admin node to primary role but it gives me the following message whenever I try to login:
You are required to change your password due to inactivity in your account.
Please login to primary to change your password.
How do I do this, if Primary node is dead?
I tried to reset password using CLI, but no luck, get pretty much the same warning:
ACS02/admin# acs reset-password
This command resets the 'ACSAdmin' password to its original value.
Are you sure you want to continue? (yes/no) yes
Administrator password can be reset only on a PRIMARY instance.
Due to some fault, I cannot login to it using my AD credentials (could be an issue with AD-ACS integration on this node). Luckily, we have migrated 95% of our infrastructure to TACACS service on ISE 2.1... but there are still devices managed by ACS. So, I am a bit desperate. Go via full recover of Admin node? Re-deploy, recover from backup? Ohhhhhhhh. It is also a physical appliance, which means I have to go to DC to be able to do this.
Has anyone experienced something similar in the past? Thanks
