06-26-2017 12:52 AM - edited 03-05-2019 08:45 AM
Hi everyone,
I have problems with the Cisco887va-k9 router. I use this for connettivity adsl2+ or vdsl. After about 10 days this router goes to block, I can not ping it but the adsl or vdsl session is always up! Of course I have to reboot the router to restore connectivity. Have you had any similar problems? I use this especially for voip connectivity, but I do not know where the problem may be.
This is my configuration for VDSL.
CISCO-ROUTER#show running-config
Building configuration...
Current configuration : 3541 bytes
! No configuration change since last restart
version 15.6
service password-encryption
hostname CISCO-ROUTER
boot-start-marker
boot-end-marker
enable password 7 XXXXXXXXXXXXXXX
aaa new-model
aaa session-id common
ethernet lmi ce
clock timezone Mytime 2 0
ip dhcp excluded-address 192.168.7.1 192.168.7.10
ip dhcp pool LAN
network 192.168.7.0 255.255.255.0
default-router 192.168.7.1
dns-server 8.8.8.8 8.8.4.4
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ2107E0VQ
username admin password 7 XXXXXXXXXXXXXXXXX
controller VDSL 0
operating mode vdsl2
interface ATM0
description LASCIARE IN SHUTDOWN PER FTTCab VDSL2
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
interface Ethernet0.835
description PER PPPOE su VDSL2
encapsulation dot1Q 835
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0
switchport access vlan 100
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan100
description LAN
ip address 192.168.7.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
hold-queue 100 out
interface Dialer0
no ip address
interface Dialer1
description PPPoE per FTTC VDSL2
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
no ppp chap wait
ppp pap sent-username XXXXXXXXXX password 7 XXXXXXXXXXXXXXXX
no ppp pap wait
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat translation udp-timeout 500
no ip nat service sip udp port 5060
ip nat pool PORTFWD 192.168.7.2 192.168.7.2 netmask 255.255.255.0 type rotary
ip nat inside source list 100 interface Dialer1 overload
ip nat inside source static tcp 192.168.7.2 8088 interface Dialer1 8088
ip nat inside source static udp 192.168.7.2 5060 interface Dialer1 5060
ip nat inside destination list 101 pool PORTFWD
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 100 permit ip 192.168.7.0 0.0.0.255 any
access-list 101 permit udp any any range 10000 12000
access-list 101 permit udp any any range 25000 60000
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
password 7 xxxxxxxxxxxxxxxxxxxxxxxxxx
no modem enable
line aux 0
line vty 0 4
transport input telnet ssh
scheduler allocate 20000 1000
ntp server ntp1.inrim.it
end
CISCO-ROUTER#
I have the same problem with adsl router.
Thank you all.
Simone
06-26-2017 02:21 PM
Hi all, probabily is this bug?
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCum44673/?referring_site=bugquickviewredir
thanks
07-05-2017 11:50 AM
Can not anyone help me?
Thank you
07-05-2017 01:05 PM
I have made a few changes to your configuration, try those and check if that makes a difference:
version 15.6
boot-start-marker
boot-end-marker
aaa new-model
memory-size iomem 10
ethernet lmi ce
ip dhcp pool LAN
ip cef
no ipv6 cef
controller VDSL 0
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan100
description LAN
ip nat inside
no ip virtual-reassembly in
ip tcp adjust-mss 1452
hold-queue 100 out
interface Dialer0
no ip address
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
no ppp chap wait
no ppp pap wait
no cdp enable
no ip http server
ip nat inside source route-map ISP_OUT interface Dialer1 overload
route-map ISP_OUT
match ip address 101
match interface Dialer1
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
end
07-06-2017 12:36 AM
Thank you for your answer. I will try these changes and update you.
Thanks!
Simone
