06-26-2017 03:16 AM - edited 03-11-2019 12:48 AM
Hi Guys
I’m trying to export ACS policies from ACS 5.8.1.4 to be imported later on ISE 2.2 using the ACS-MigrationApplication-2.2.0 tool.
I’m able to export all objects except the Access Plicies. In the Migration tool logs I see that the Service Selection Policy is not supported.
Below the different logs:
ACS 5.8
ACSLab
ASEAPTLSPhone
Rule: SSPPhoneEAPTLS
Description: Enabled SSP rule 'SSPPhoneEAPTLS' points on a service that is not a network
access service. This is not supported by ISE
ASMD5Phone
Rule: SSPPhoneMD5
Description: Enabled SSP rule 'SSPPhoneMD5' points on a service that is not a network
DefaultNetworkAccess
Rule: Radius
Description: Enabled SSP rule 'Radius' points on a service that is not a network access
DefaultDeviceAdmin
Rule: Tacacs
Description: Enabled SSP rule 'Tacacs' points on a service that is not a network access
Summary:
*Service Selection Policy : Unsupported
*Authentication Policy : Supported
*Authorization Policy : Supported
Not all policies are compatible with ISE 2.2. Out of security concerns,
the migration application will not migrate any of your ACS 5.5/5.6/5.7/5.8
policies.
End of Report
I have attached the different Access Services in the Lab.
I have suspected the: ANY and the compound conditions with AND and OR but they are not the issue.
Any suggestion will be appreciated! Don't hesitate if you need any further information
Best regards
02-06-2018 09:02 AM
Hello Abdollah,
I am having the same issue. How did you fixed?
Best Regards,
Daniel
