Warning message
Inter VLAN Multicast Routing on SG300-10
Answered Question
I have a network made of 2 VLANs connected via the Cisco Small Business SG300-10.
One computer on VLAN2 needs to transmit multicast data to several devices in VLAN1.
I read on another forum that inter-VLAN multicast routing is not possible with SG300 Cisco switches. Is that true ?
If so, which switch (working on L3) do I need to use ?
Robin
Correct Answer by jonrodr2 about 1 month 2 weeks ago
Hello, my name is Jonathan and I am part of the Small Business Department.
I apologize for any inconvenience with the unit, it is correct the Small Busines units don't support this feature, so you will need a router that is capable of doing it, I am not aware of any other unit but you can contact our Presales department and check what they can find out. Thanks
Phone: 1-800-553-6387
Overall Rating: 5 (1 ratings)
Correct Answer
jonrodr2 Fri, 06/30/2017 - 13:49
  • Cisco Employee,
