Cisco 3850 Stackwise
Shvan Ahmad
Hi All,
I have just installed Cisco IOS XE Denali 16.3.3 version on my 3850 switch model WS-C3850-48P-E. By installing this version I should be able to enable StackWise Virtual Configuration but for some reasons I'm not able to use this command in global config. For example: I have the following two options in global config.
VSS-Test2(config)#stackwise?
% Unrecognized command
and
VSS-Test2(config)#stack?
stack-mac  stack-power  stackmaker  stacks
Thanks for your help!
Yannick Vranckx
Level 2
Level 2
If i am not mistaken. Stackwise Virtual configuration is only supported on the following models:
Yannick Vranckx
Level 2
Level 2
Leo Laohoo
I agree with Yannick.  Your switch sub-model won't support Stackwise Virtual.  I'm not sure if it even supports Horizontal Stacking.
Shvan Ahmad
Thank you Yannick for the replay.  According to the following link, the WS-C3850-48P should be able to do Stackwise Virtual.  http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/data_sheet_c78-720918.html
But then there is another document which you provided me the link,  saying you can do it but only on certain model of 3850s. Kinda confusing.
