06-26-2017 01:02 PM - edited 03-12-2019 02:37 AM
can some please help me with this issue ?
asasfr-boot>system install ftp://10.30.2.40/asasfr-sys-6.2.0-362.pkg
Verifying
111
Upgrade aborted.
ASA-5525-1(config)# SH RUN BOOT
boot system disk0:/asa981-smp-k8.bin
boot system disk0:/asasfr-5500x-boot-6.2.0-2.img
boot system disk0:/asasfr-sys-6.2.0-362
thanks
Solved! Go to Solution.
06-28-2017 07:16 AM
The references you are citing about 6.0 and 5.3 etc. are for upgrades. You are not doing an inline upgrade but instead building a new image. When re-imaging, the boot image (img file) must match the version of the system image (img file).
I don't know how you got to the initial condition. It is probably best to start over with a module uninstall:
sw-module module sfr uninstall
...and then and follow the following procedure exactly while using the version 6.2.0 files:
http://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/reimage/asa-ftd-reimage.html#id_51507
I have several such re-images and never encountered any problem.
06-26-2017 07:13 PM
You're mixing the sfr (FirePOWER) module and ASA software commands. The "boot system" commands should not be used for the "asasfr..." images.
To show the version and status of the sfr (FirePOWER) module, you would use the "show module sfr detail" command.
The "system install" command is to install the full FirePOWER module software from the "asasfr-boot" prompt in the partially initialized module as you show.
Given that your bootstrap image was asasfr-5500x-boot-6.2.0-2.img, you should be using the system software "asasfr-sys-6.2.0-362.pkg" and then, from the GUI, upgrade it to patch 6.2.0.2.
06-27-2017 07:33 AM
thank you for your respond,
i have new device and already update the ASA and ASDM. and i downloaded the FirePOWER image. Now i tired to download the pkg from asasfr mode file it shows the below massage
Verifying
111
Upgrade aborted.
the show version command shows that i have firepower :
Firepower Extensible Operating System Version 2.2(1.47)
and i want to download 6.2.0
06-27-2017 07:53 AM
Please share the output of:
06-27-2017 08:19 AM
sh module sfr details
Getting details from the Service Module, please wait...
Unable to read details from module sfr
Card Type: Unknown
Model: N/A
Hardware version: N/A
Serial Number:
Firmware version: N/A
Software version:
MAC Address Range: 00a3.8ecf.c864 to 00a3.8ecf.c864
Data Plane Status: Not Applicable
Console session: Ready
Status: Recover
06-27-2017 08:19 AM
OK, we would expect that status since your module is in recovery mode.
Please confirm the MD5 checksum of the file "asasfr-sys-6.2.0-362.pkg" you downloaded against what is posted on Cisco's download page.
06-27-2017 08:19 AM
Thank you very much .
could you please give me more detail?
this is my first project
06-27-2017 08:44 AM
We need to confirm you have a good download. If you hover over the file in the cisco.com download page, you will see the checksum value. Copy it to notepad.
Then use a checksum utility like the Microsoft cli one or a downloadable graphical one to confirm you have a good copy downloaded by checking the checksum of your local file copy.
https://www.microsoft.com/en-us/download/details.aspx?id=11533
http://www.winmd5.com/
06-27-2017 09:25 AM
Thank you .
i did your instructions and the checksum match .
I started from the beginning and i download old version which is 5.3.1 image .
when i login to SFR session to boot the pkg its shows me the same error
asasfr-boot>system install ftp://10.30.2.40/asasfr-sys-5.3.1-155.pkg
Verifying
111
Upgrade aborted.
asasfr-boot>
06-27-2017 01:29 PM
hi,
kindly please try this ftp://user:pass@10.30.2.40/asasfr-sys-5.3.1-152.pkg
note: user:pass you have to define as in your ftp server
also make sure if you running a filezilla server create username and password to match them with ftp://user:pass@x.x.x.x
also please be advised, with version 9.7.x you need to run 6.x
Kind Regards,
sheraz.
06-28-2017 07:01 AM
Thank you for your respond
i did all step above
this is show version
sh version
Cisco Adaptive Security Appliance Software Version 9.8(1)
Device Manager Version 7.8(1)
and i tried to download SFR 6.2.0 ITS give me same error
after i read the Release note for 6.2.0
its say i have ti have 6.0.0.0 version and 6.0.0 have to have 5.4.0
so i start to download the 5.3.0
and still some issue
06-28-2017 07:16 AM
06-29-2017 10:32 PM
Thanks for rating. Did it work for you when you restarted from the beginning?
06-30-2017 11:43 AM
yes, thank you :)
06-14-2019 04:02 AM
Thanks this command at least worked for me and its showing downloading and extracting.
