Hi!
I have four RV325 routers. I wanted to connect my lab router to WAN1 of RV325A, then from a network port (Port 7) of RV325A to WAN1 of the next RV325, which I am calling RV325B. I have internet access on RV325A, but not on RV325B. Of course, the down-stream routers RV325C and RV325D do not have internet access.
I tried it out-of-the-box with Factory defaults. I tried disabling IPSec, PPTP, L2TP, and VPN. It is setup as all DHCP. I am using the default 192.168.1.1 VLAN 1. I upgraded the firmware. I read through a number of posts and other information on the web and read the manual.
I have used this type of setup with simpler routers, but this is the first time with Cisco.
I have a work-around and will be able to accomplish what I am trying to accomplish. However, I would like to know why it would not work to connect the LAN port of an upstream RV325 to the WAN port of a downstream RV325.
Please let me know your thoughts.
Best,
Kevin
