Need to force anyconnect clients to use a mandatory route instead of current split tunnel mmode
Dirk Evelyn
I have an AnyConnect remote access solution on MY ASA 5510 that is setup to use split tunneling. I want to force a route not to use the spilt tunnel but to use my Internet Gateway that is not the ASA.I hope this is possible but I cant seem to find out how to do it. I foubnd some information on access-lists but don't think that will apply.
dperezoquendo
So the split tunnel already allows the route to behave how you want it unless you meant tunnelall.
split tunnel = only traffic headed to company network will be sent through vpn connection --- other traffic will go out through normal network connection.
tunnelall = default config, all traffic from your computer will go through VPN connection.
If your ASA is already setup for split tunneling, I believe you probably need to verify network settings on your PC. Verify that "Use default gateway on remote box" is unchecked under the Network Connections -> Your VPN Connection (Properties) -> Networking -> IPv4 -> Properties -> Advanced tab. Depending on what version of Windows you have, you may have to disable it differently.
