Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929751members
1244643discussions
Community Activity
1921 Router Config Help
Hello, I know very little about configuring cisco hardware and need some help..... we are currently running an 1800 router and I obtained a new to me 1921 router and would like to replace the 1800 router with the newer one, I managed to get it factor...
cwasilak by Level 1
  • 189 Views
  • 14 replies
API call to get agent status
Hi, i am trying to get the Finesse agent status from asp.net using javascript but all i get is server responded with a status of 415 (Unsupported Media Type).what i got so far var agentID = "user"; var finesseEndpoint = "http://mydomain.com:8082/fine...
jfigueroa by Level 1
  • 1 Views
  • 0 replies
Cisco Archive config - any changes / Cisco commands
Hello Professionals,I have configured Archive to log config whenever type write memory.I would like to use this auto backup in other way too.Could anyone tell me how to configure followings?1. Is there possible to backup config whenever I make any ch...
eeebbunee by Level 1
  • 5 Views
  • 0 replies
Resolved! No answer ring issue
CUCM 12.5, I have a Line Group with 3 users, top down then hunt pilot to VM.  The RNA Reversion Timeout is set to 15 (per Cisco).  One of my users (the first in the line group) sent me a message saying that incoming calls ring to her phone about 10 t...
Forward traffic from subnet to another on C3750
hi guys thanks for your suggestions in advancei just reconsidered my whole message. after trying some things. i think i need to set up acl but i'm far from good at it.what would be the ip access-list extended or access-list lines that'd allow me to h...
gabecz by Level 1
  • 183 Views
  • 4 replies
Need to delete/remove a BOT.
Someone within my organization created a BOT with the same name as a user and it is causing confusion as when you look up the user it looks like they are in the directory twice. I have double checked the end user and made sure they didn't create the ...
CJinNV by Level 1
  • 33 Views
  • 1 replies
ISR 4k Netflow not sending data
I've got 15+ Cisco ISR 4000's (a mix of 4331s and 4551s) in our network and when trying to setup Netflow to PRTG, It seems that when I hit 5 interfaces that need to be monitored, there is always 1 that won't come up in PRTG and that doesn't send data...
lvl3mp by Level 1
  • 20 Views
  • 0 replies
CDP Mismatch from CDP: Why?
Switch A, Cisco 9300, VTP mode transparentinterface GigabitEthernet1/0/5switchport access vlan 3switchport mode accessSwitch B, Cisco 3560, VTP mode transparentinterface GigabitEthernet1/0/1switchport access vlan 3switchport mode accessVlan 3 (L2) vl...
WIFI design for the warehouse
Hello everyone. Much has been written and said about the design of WIFI for warehouses.I would love to hear from your experience in order to make a decision on a complete system from MERAKI16 corridors each about 60 meters long. shelf's between each ...
yairp by Level 1
  • 2183 Views
  • 10 replies
Multiple sub interfaces with Native vlan's?
Sorry, I am reposting because I want the community to see this because where I previously posted, the thread shows resolved already.I have an ASR 10g interface that is connected to a native vlan1 in a HP switching fabric (8 switches) for databases (i...
jroy777 by Level 1
  • 35 Views
  • 0 replies
