06-30-2017 10:00 AM - edited 03-01-2019 01:14 PM
I try to transfer a file to UCSM for firmware upgrade but the proccess gets stuck in 73% and current task says:. " sync image to subordinate".
Also I get one critical alarm and 3 warnings about faild copy image.
I check the bootflash space an it has 52% and I ony have two files on firmware download task.
Have any idea?
Debbie
07-02-2017 12:45 PM
Hi Debbie
It seems that the .B bundle is causing the problem ?
Q. Have you successfully copied the .A bundle ?
Maybe the .B bundle is corrupted ? I would try another download from Cisco CCO.
Q. what is the running version of UCS ?
07-03-2017 01:11 PM
Hi Walter
I had the same problem with both files. I also thought that maybe the bundle was corrupted so I download again the file and still had the problem.
The current version is 2.2.6c
Debbie
07-05-2017 09:33 AM
Greetings.
You can also see 'sync/copy' issues if there are file system issues on the destination (subordinate) FI.
Please confirm you have plenty of space in bootflash on that FI. You may also want to connect to the nxos on that FI and run the following:
#show logging log | in ext3|inode
#show logging nvram | in EXT3
If you do see something regarding 'ext3 file system error' or 'ext3_new_inode: IO failure' then you will want to contact TAC as they will need to boot the FI into basic boot loader, along with dplug file, so a file system check can be run.
Kirk...
07-21-2017 07:28 AM
Hi Kirk,
Both FI have 25% of used.
I run the commnad you mention and I get the following output.
2017 Jul 21 09:23:37 USFQ-FI-A-B Jul 21 09:23:37 %KERN-2-SYSTEM_MSG: [26352191.378957] EXT3-fs error (device sda3): ext3_add_entry: bad entry in directory #752200: rec_len is too small for name_len - offset=272, inode=719724, rec_len=36, name_len=44 - kernel
So what I understand is that I need to opend a case with TAC.
Debbie
07-21-2017 04:10 PM
Greetings.
Yes, basically TAC will install a special dplug file, and reboot the FI (will need console connection), break into the boot loader sequence, early enough before file systems are mounted so e2fsck can be run to check/repair the ext3 file system.
Kirk...
07-24-2017 06:02 PM
Did TAC help you get the FI file system Issues resolved?
Kirk...
07-26-2017 02:38 PM
Hi Kirk,
I opend a case with TAC.
They couldnt upload the debug plugin onto FI B so they need to rebuild the switch to attempt to fix out the corrupted partition.
We are planning the maintenance window for next monday. I would let you know how it go.
Debbie
