07-05-2017 12:16 AM - edited 03-17-2019 10:42 AM
Following is the message from SIP ISP.
A single registration coming multiple times is not an issue and is actually expected under certain circumstances. What I am seeing through is between 130 and 150 simultaneous registrations active with us from your WAN IP of 205.XXX.XX.XX when you should have a grand total of 2 between the two online trunking devices on the account.
Can anyone tell why CME is sending such request.
Thanks in advance
Jayesh
Solved! Go to Solution.
07-05-2017 02:56 AM
When you configure your DNs make sure that you use the keyword no-reg with the number command. This will avoid the DNs to register with registrar server such as ISP.
07-05-2017 02:56 AM
07-27-2017 02:31 AM
Thanks Mohanned al Baqari for your prompt reply. I made changes on all the DN's with no-reg command on numbers and it works exactly you said.
Thanks again for your help and support. You are a STAR
