UCCX PORTS AND ROUTE POINT
ansarjavaid54
Hello guys.
Today i installed UCCX with demo license. Am stuck in route point and cti ports registration process. They are in created in cucm but whith status of none normally they are registered with call manager...
Immediate response will be highly appropriated.
Jitender Bhandari
Did you perform all the required steps as stated in below link
http://ciscoshizzle.blogspot.in/2013/04/uccx-configuration-basic-set-up-and.html
https://ccieroot.com/2015/07/29/uccx-integration-with-cucm/
(Rate if it helps)
JB
is there a way here to send you a private message Jitender Bhandari
Adding on to the below links shared by JB, if the integration is as per the links you can try below procedure as well
Reset the username and password for Jtapi user on CCX under Telephony Subsystem.Restart the CTI manager on all CUCM servers. Restart CCX engine.
You can also do the Data Resync.
Abhay
Kindly rate all helpful posts !!!
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
