UCCX 11.0 - How do I show CSQ info on the handset instead of the CTI Port?
Jul 6th, 2017
Hi everyone,
I'm currently running UCCX 11.0.1.10000-75 (ES07-38) and CUCM 11.0.1.20000-2. I am using UCCX scripts to route and place calls into CSQ's using the select resources step.
The Call Center I administer has  Agents who answer many different CSQ's at once. They need to know which CSQ the call they are answering came from, so they know how to greet the caller.
For example: CSQ A would be for calls pertaining to Company A and CSQ B would be for calls pertaining to Company B. My agents need to know to answer "Thank you for calling Company A" when they receive a call from the Company A CSQ.
I am currently using the "Set Enterprise Data" step,  which allows me to use Finesse to show which Queue a call is coming from, however; I need the handset itself to be able to do this. My Agents login to Finesse and basically never interact with it again (and the don't partically like having to depend on a webpage for this info). We work in a situation where our Agents do a lot of web research, and it's not very practical l to have Finesse be the front Window at all times, since they often have tens of windows or tabs open at all times.
There has to be a way to show queue info on our 7962 handsets themselves. Instead of showing the CTI port on the handset (which is basically useless info), I want to show the CSQ that the call is originating from.
Thanks all!
Anthony
Chris Deren Fri, 07/07/2017 - 05:55
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
No, there is no way to send CSQ info to the phone display when using Finesse desktop. I suppose you could use IP Phone Agent instead of desktop Finesse to see if you can get what you are looking for.
Anthony Zhang Thu, 07/13/2017 - 06:45
OK, this is somewhat dissapointing, as it seems like a very basic and necessary feature :/
Thanks for responding.
Anthony
Deepak Rawat Fri, 07/14/2017 - 00:25
  • Cisco Employee,
Chris is correct in saying that it is not possible to use CSQ information on the phone if agents are using Finesse Desktop. If you want this to be displayed on phone then the only way is to configure Finesse IPPA and let the agents use that for handling Contact Center calls.
Deepak
CHRIS CHARLEBOIS Wed, 07/19/2017 - 14:37
  • Silver, 250 points or more
I wonder if there isn't a way to do this.  It wouldn't be scalable and it would require multiple scripts.  If you create two different Call Control Groups, you should be able to configure the Display name for each group. If the two CSQs are assigned today by different scripts, then just associate the application for each side with a different Call Control Group.  If, however, they are both in one script, then you will need to split at least one of them off into a new script, which is called by the first and is assigned to an application that is configured with the other CCG.
Please note:  I have not tested this and this is a hack.  It's just a hack that *should* work.
