07-06-2017 08:12 AM - edited 03-14-2019 05:25 PM
Has anyone found a way to affect multiple user variables using one set variable node? See attached screen shot of what I tried that did not work.
Versus using a set variable node for each user variable I would like to use a single set variable node to assign a value to multiple user variables.
Am i trying to accomplish the impossible?
07-06-2017 01:15 PM
I can't see how it's possible. The variable that you're setting is only configured in the Object Type + Variable drop-down boxes, and in the 'Value' it should only contain the value itself.
I understand the need, as we're also making complicated scripts with lots of 'SET' nodes + the amount of the nodes per script are limited, but unfortunately I can't see how it's possible.
07-07-2017 07:24 PM
You can certainly concatenate them and produce something like "010" and later on you can parse "010" with the built-in substring function.
Geoff
07-08-2017 08:37 AM
Hi, Can you please show us an example of how you do it? If it's possible it can help me also reduce lots of script nodes.
Thanks.
07-09-2017 07:22 AM
I don't believe that Geoff's approach is really going to save you any nodes, if anything it might actually add more nodes later on when you try to read/set them. Ultimately, if you want to have less set nodes, you're going to have to change your logic. Maybe have a single open/close variable with multiple positions XYZ (based on what Geoff mentioned). However, the savings you're introducing are minimal. Personally, I no longer keep open close in ICM, I do it all in the IVR and pass the data to ICM, makes for much cleaner scripting and less logic all around.
david
07-09-2017 07:41 AM
I agree with David - you are unlikely to save any nodes. I have never seen script writers really care that much about the number of set variable nodes or IF nodes required to perform the required logic. You can certainly try to avoid reproducing the same logic in a number of scripts by pulling that up a level into a common script and then distributing to your queue scripts, but it does not always work.
I do have Admin scripts and global variables for open/close/holiday but do not have any day of week or time of day nodes in those Admin scripts. I fetch the data using an App Gateway node to a back end system (for example: exony or the one our company uses) and the Business Users have a web based front end to change schedules.
David knows what I am talking about because he used to work here. ;-)
Geoff
07-09-2017 07:56 AM
07-10-2017 12:08 AM
Hi David,
Can you please show me how you create open close script in IVR ( I believe you are, referring to call studio here)...
