Global protect VPN is disabling WLAN
ittechk4u1
Level 4
Level 4
Hello experts,
Step1: client connected with WLAN successfully.
Step2: Start Global Protect VPN client on machine
Step3: Click on connect then its automatically disabling WLAN adapter.
anyone faced the same issue or have a solution of it ?
2 Accepted Solutions
Sandeep Choudhary
Are you having issue with all clients or only with few ?
is it win 7 or win 10 ?
Please also check...
Restart and check your BIOS for the following:
- device options: WLAN / LAN switch: if on, turn it off.
- Wireless options -> check for LAN/WLAN, and turn off the settings or mess with them.
Dont forget to rate helpful posts
Only WIN 10 then it must be this issue!!!
Info: "Windows 10 handles Auto Switching the LAN/WLAN, so you should disable it in the BIOS." and try again.
8 Replies 8
Scott Fella
Have you posted this on the GlobalProtect forum as well?  Doesn't seem to be an issue with the wireless if they can connect fine.
-Scott
-Scott
Thanks Scott.
I will posts this issue on Global Protect forum as well..
Sandeep Choudhary
Here are the answers:
1. Only with 3-4 clients...
2. All affected clients are WIN 10...
I will try your method and post the result here..
Thanks Sandeep
you guys saved me.
I disabled LAN / WLAN auto-switch in BIOS and it worked. I will also try on other win 10 laptops.
Thanks you guys.
Glad it helped. Thanks for rating.
THEuda
It helped start the service from automatically reset manually.
