ISE integreation with Stealthwatch
nithinrs78901
Please help me to how to integrate ISE with Stealthwatch
Here are the ISE/Stealthwatch integration guides I used previously.
https://communities.cisco.com/docs/DOC-64012#jive_content_id_Cisco_Stealthwatch
The import thing to note when using pxGrid is the certificate template used to sign the pxGrid certificates, must contain certain attributes, which is detailed in the guides. Read the guides carefully and you should be able to integrate ISE with Stealthwatch.
