ā07-13-2017 12:56 PM - edited ā03-17-2019 10:46 AM
I have the following setup. SIP trunk Provider --> Cube --> SIP trunk to CUCM.
We are having a special dial pattern to dial outside. *9*external_number. The *9* is removed on the outgoing dial leg of the CUBE.
When I make a call from my IP communicator in the format *9*0032258785 the number on the phone is changed to 0032258785 after the call is connected.
Is there a way to keep the number with the leading *9* on the screen?
We have a issue with our IVR. The IVR is monitorring the call for reporting purposes. But when the call is connected we receive a <calledid>0032258785. This should remain *9*0032258785
Kr,
Laurent
Solved! Go to Solution.
ā07-14-2017 03:38 AM
Hi Laurent,
You need to use connected number display as explained nicely by Vivek in this document:
https://supportforums.cisco.com/blog/12726551/connected-number-display-phone
Rajan
Pls rate all useful posts
Hi Laurent,
Rajan
