AP not joining WLC...
ljustl
Hello all,
Working on wireless, CAPWAP is initiated, however AP cannot be joined or discovered by WLC..
using 3700 AP and 2504 WLC
Show run and outputs are attached. (for core, access sw, WLC and AP)
CAPWAP State: Join
Finding DTLS connection to delete for AP (192:1xx:xxx:xx/xxxxx)
Disconnecting DTLS Capwap-Ctrl session 0x17aa3ba8 for AP (192:1xx:xxx:xx/xxxxx)
CAPWAP State: Dtls tear down  acDtlsPlumbControlPlaneKeys: lrad:192.1xx.xxx.xx(xxxxx) mwar:192.1xx.xxx.x(xxxx)
DTLS keys for Control Plane deleted successfully for AP 192.xxx.xxx.xx
DTLS connection closed event receivedserver (192.xxx.xxx.x/xxxx) client (192.1xx.xxx.x/xxxxx)
Entry exists for AP (192.1xx.xxx.xx/xxxxx) apModel: AIR-AP3702I-UXK9  apType = 41 apModel: AIR-AP3702I-UXK9
I need help!!!!
2 Accepted Solutions
Product Version.................................. 7.6.120.0
I must be getting old.
Ok, so the controller is running a very, very old 7.6.120.0
*spamApTask4: Jul 08 12:16:29.596: apType = 41 apModel: AIR-AP3702I-UXK9
And the AP is a 3702I ... but a -UX.
Now, -UX APs were first supported with 8.0 controller firmware.
So, upgrade the controller to 8.0.X and see if it improve things.
- Yes..
Reboot your controller.
43 Replies 43
Leo Laohoo
If the controller is a 3650/3850, post the complete output to the command "sh ntp a".
all the times are set as current. that is from couple days back. i did set WLC current time on GUI.
controller = 2504
core = 3650
access = 3560
On the controller, post the output to the command "sh time".
its current. i modified on GUI. Do you still want to see it?
take a look at from_ap txt, it's from today
AP_message is from July 8.
That's why I'm suspecting the time-and-date settings for the controller is off.  Today's date is NOT 08 July.  Today is 15 July 2017 (unless you're in a time warp).
right, but as i mentioned, that debug details are from july 8 and there were no changes made. I'm stuck since then.
Post the complete output to the WLC command of "sh sysinfo".
i've attached the sh sysinfo
below are sh time
(Cisco Controller) >show tim
Time............................................. Sat Jul 15 09:07:58 2017
Timezone delta................................... 0:0
Timezone location................................ (GMT -5:00) Eastern Time (US and Canada)
NTP Servers
NTP Polling Interval......................... 86400
Index NTP Key Index NTP Server NTP Msg Auth Status
1 0 128.xxx.xxx.xx AUTH DISABLED
Maximum number of APs supported.................. 5
How many APs have already joined the controller?
i have two connected, but not associated with the controller. 0 found.
okay, i will try to upgrade to 8.0.140.0 on controller and let you know.
Does it mean that -UX APs are not suppported on 7.6.120.0?
after upgrading to 8.0.140.0 AP joined WLC. So -UX APs are not compatible with 7.6.120 ios????
1 of AP is still blinking green and red. but i guess i can manage that.
I have another AP that is not joining WLC. i reset the AP and it's keep rebooting.... error message below..
2700/3700 -UX APs are supported from 8.0.X (and later).
After the AP has joined the controller, the "-UX" domain needs to be provisioned and this can only be done using Android/Apple app.
Cisco Aironet Universal AP Priming and Cisco AirProvision User Guide
Universal AP Regulatory Domain Deployment Guide
