How to associate the Agent and Phone on PCCE 11.5
Jul 15th, 2017
Hello
I have just done for PCCE 11.5 initialization (fresh installation) and I would like to know how to associate the Agent and IP Phone for logging to finesse.
I have read this configuration guide and no more details to explain it.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_...
Could you give me the configuration guide or tell step by step to do any the foundation on PCCE ?
Thank you in advance.
I am not a PCCE person, but I am pretty sure it's the same as UCCE.
There is no static association - to support hot-desking, there cannot be a static association. An agent can log in with any configured phone and the mapping is established dynamically.
In UCCE you need to create Agent Targeting Rules - and I assume PCCE also has that. See if you can find that in the Web admin.
Geoff
chatchavan_u Sun, 07/16/2017 - 07:33
I could login successfully.
Thank you for your support
Chatchavan
chatchavan_u Sun, 07/16/2017 - 08:29
Yes, you're right. PCCE auto created the Agent Targeting Rules at time of initialization.
Chatchavan
