07-19-2017 12:41 AM - edited 03-08-2019 11:22 AM
we are trying to do password recovery on cisco 1941 router with password recovery functionality disable on it.
we have purchased the router from ebay with no where to return so need to break the password of this, so please help if anyone has done this before.
Thanks and regards.
07-19-2017 01:38 AM
Look at the image below.
Don't forget to rate our useful post(s).
07-20-2017 11:56 PM
hello LEO,
what is the exact break sequence to enter ROMmon mode.. will you please guide me with this issue
07-21-2017 12:10 AM
If you eject the CF and power on the router does it take you straight to ROMmon?
If it does, enter the command "confreg 0x2142", insert the CF and reboot the router.
If the router boots up normally, erase the present config (because it has the setting password recovery disabled) and then change the config-registry back to 0x2102.
07-21-2017 01:16 AM
