07-19-2017 06:18 AM
Hi Guys,
Just updated to PI 3.2 ( new install and restore) but it would appear that the Network Devices Show a lot of objects in the navigation tree titled "Access Points" yet you can neither click on them or remove them (screenshot attached)
Just wonderign if these are fed from somehwere else and if they can be removed somehow? Or is is a bug someone else has come across?
Thank you in advance,
Niko
Solved! Go to Solution.
07-19-2017 07:54 AM
That looks like some database corruption. It would probably require TAC assistance to clear it up. I'd recommend you go ahead and open a case.
I had some oddness in the wired topology maps on my upgrade but was able to clear it up manually.
07-19-2017 06:56 AM
I've not seen that on my PI 3.2.
Is the parent WLC for the APs managed (and synchronized) by Prime Infrastructure?
07-19-2017 07:03 AM
yes it is a 5508 controller and its managed / synced this morning
07-19-2017 07:54 AM
07-19-2017 07:54 AM
Thank you Marvin, i was looking if someone else might have see it when upgraded, but TAC is the logical course of action here.
Thank you!
