Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1914948members
1215663discussions
Community Activity
2024년 3월 ATXs 일정 및 다시보기
 Ask The Expert(ATXs) 세션에서는 도입하신 시스코 솔루션의 구축과 운영에 필수적인 기술 지식을 라이브 Q&A와 데모를 통해 생생하게 제공해 드립니다. 아래 일정에서 필요한 세션에 등록하시고 지난 세션은 다시보기를 통해 확인해 보세요. ATXs에 대한 궁금한 점은 atx_korean@external.cisco.com로 문의해 주세요. Campus Network & WANThousandEyes 대시보드, 스냅샷 및 링크 공유를 사용...
请教3850交換机接口怎样引用PBR(策略路由)?
引用命令不知道是那里問題?g_core(config)#ip access-list extended hkbng_core(config-ext-nacl)#10 permit ip 10.105.20.13 0.0.0.0% Incomplete command.g_core(config-ext-nacl)#10 permit ip 10.105.20.13 0.0.0.0 anyg_core(config-ext-nacl)#exitg_core(config)#route-map hk...
D_W by Level 1
  • 54 Views
  • 4 replies
WLC Guest Auth
Hello,What should we do if sometime the web auth for guest WLAN is not showing?
hs08 by Spotlight
  • 52 Views
  • 0 replies
Jabber MRA DNS query for collab edge
Hi, We have a MRA deployment in our lab (simulating the internal and external env). We have got the Android, and CSF device working, connected to expressway edge. But our IOS devices are not working. Upon investigation we find out the Iphone/Jabber i...
3802 AP LED turn off after registered with WLC
The LED light of 3802 AP is off after registered with 9800 WLC . But the 3802 access point is still working perfectly in providing the wireless connection to the end device .  We have factory-reset the AP and issue remain the same after the AP regist...
Webex API Update a Personで外線番号を剥奪した際、ロケーションに変更が生じる事象について
以下のケースで、Webex APIのユーザー情報更新API(Update a Person)で外線番号を剥奪した際、所属しているロケーションから抜けてしまい、ロケーション未所属となる事象を確認しました。外線番号を剥奪してもロケーションには変更が生じず、所属しているロケーションのままになるようにしてほしいです。【前提条件】操作対象のユーザーアカウントの状態・ライセンス:Webex Calling Professionalを所有・電話番号:内線番号と外線番号を使用・ロケーション:所属(例としてTok...
YH1230 by Level 1
  • 118 Views
  • 2 replies
[CTC テクノロジー共催] Ask Me Anything フォーラム 2024 - Catalyst 9000
質問受付期間を延長しました!Ask Me Anything フォーラム 2024/3/1(金)~ 2024/3/15(金) ※期間中、ご質問下さった方を対象にプレゼント抽選企画があります。お楽しみに!   Cisco Catalyst 9000 スイッチ をお使いの方、導入をご検討の方、サポートに従事されている方、お困りのことはありませんか?Ask Me Anything フォーラムイベントでは、選りすぐりのエキスパートがみなさまのご質問にお答えします! 【開催概要】 1. 開催(質問受付)期間...
CTCT AMA Main banner double logos.png Reply.png CTCT Corporate ja.png Expert 1.png
Eri Mizuno by Community Manager
  • 1322 Views
  • 12 replies
  • 2 Helpful votes
