07-20-2017 02:18 AM - edited 03-08-2019 11:23 AM
Hello all,
We have a black optical fiber (10G) between Catalyst core switch within SFP DWDM-SFP10G-56.55
I search to know if we can migrate the fiber to Nexus 6000 with the same SFP ?
Despite research on the matrix compatibility, i didn't find anything.
Could you tell me if the SFP are compatible please or share documentation.
Regards.
07-20-2017 06:17 AM
Up
07-20-2017 06:41 AM
additionnal information :
On Catalyst, we use Gbic DWDM-SFP10G-56.55
I believe we can use SFP DWDM-SFP10G-56.55 on Nexus. What do you think about this ?
07-20-2017 08:43 AM
There is no information on DWDM-SFP10G-56.55 being compatible with 6ks. I would contact the Cisco rep or your SE to be sure. Sometimes, they have internal documents with info that is not shared publicly. Is your Nexus a 6004?
07-20-2017 09:04 AM
Indeed, I didn't found anything about this :/
The equipment is Nexus 6001
I'm waiting for other answer. I will also contact Cisco
