07-20-2017 02:25 AM - edited 03-12-2019 02:43 AM
hi,
was trying to search and find a way to alert in solarwinds NPM if active ASA FW did a failover to standby FW?
i only find this.
can someone advise what specific snmp trap/commands i need to put on the ASA?
i currently got the below SNMP configured. is there any other 'special' SNMP trap i should enable?
snmp-server enable traps snmp authentication linkup linkdown coldstart
07-20-2017 03:06 AM
Hi John,
As far as I am aware of, Failover event is not one of the available
As an alternative could be, actually, configure the SNMP Server to poll information for the Failover State, below is the Object name and the OID:
Object:
OID: 1.3.6.1.4.1.9.9.147.1.2.1
In
Aditya
Please rate helpful and mark correct answers
07-20-2017 04:11 AM
hi,
thanks! do you have a link supporting this?
syslog is not an option as it's not a primary monitoring tool.
i only need an alert to be monitored or viewed in solarwinds NPM.
07-20-2017 04:37 AM
Hi John,
I will check for that and if I find one I will share the same.
Aditya
