07-20-2017 06:54 AM - edited 03-08-2019 11:24 AM
I would like some help with 2801. I can ping from router e.g. 8.8.8.8 but PC's
doesn't have internet and they can't ping e.g 8.8.8.8.
I think the problem is with nat and access lists and I cant find it.
I have the 2801 as second router connected to main from fe0/0. I can ping the
main router (172.20.0.1/21).
fe0/1 is for local lan (192.168.100.254/24).
Here is my setup...
Current configuration : 1314 bytes
version 12.4
hostname XXXXXXX
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$9h9a$j0J3TS8EUZaI/zLH03EK//
enable password XXXXXXXX
no aaa new-model
no network-clock-participate wic 1
ip source-route
ip cef
no ipv6 cef
voice-card 0
archive
log config
hidekeys
controller E1 0/1/0
shutdown
interface FastEthernet0/0
description wan.interface
ip address 172.20.0.6 255.255.248.0
ip nat outside
ip virtual-reassembly
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
description local.interface
ip address 192.168.100.254 255.255.255.0
ip nat inside
speed auto
half-duplex
no mop enabled
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.20.0.1
no ip http server
ip nat inside source list nat interface FastEthernet0/0 overload
access-list 10 permit 192.168.100.0 0.0.0.255
dialer-list 1 protocol ip permit
disable-eadi
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password XXXXXXXX
login
scheduler allocate 20000 1000
Any suggestions what to fix please.
Thank you.
Solved! Go to Solution.
07-20-2017 07:06 AM
Can you change your config to refer to to the access list number?
to
ip nat inside source list 10 interface FastEthernet0/0 overload
and test again?
07-20-2017 07:06 AM
to
and test again?
07-20-2017 07:20 AM
Thanks for your replay.
I works now...
I tested using static ip's in 3 pc's and all have internet.
Thanks a lot
07-20-2017 07:26 AM
Glad to know its all working for you.
Good Luck!
