07-20-2017 07:11 AM - edited 03-12-2019 02:43 AM
Hi, I am new on this area and i need some help with ASDM/ASA5515. I have to create on a ASDM a rule that enables port 443(https) tcp/udp to specific ip. Someone can help me?
Best regards!
Solved! Go to Solution.
07-20-2017 07:45 AM
Choose Configuration > Firewall > Access Rules, and click the Add Access Rule button.
Choose the interface to which this access list has to bound, along with the action to be performed on the traffic i.e., permit, select the source as any (subnet) and destination as the specific IP and protocol as tcp/443.
More info on this link:
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/91970-PIXASAopenblockports.html
Aditya
Please rate helpful and mark correct answers
07-20-2017 07:45 AM
Aditya
07-20-2017 08:37 AM
Hi Aditya!
Thanks for your help! But now i wonder which one interface i must use for this rule...
Best regards!
07-20-2017 09:47 AM
If you want to access it from Internet then you need to allow it on the outside interface.
Aditya
