07-20-2017 08:42 AM - edited 03-19-2019 12:39 PM
Dear All,
I am running CME 10.5 and I have 8811 & 8831 SIP phones.
Phones are registered but I have couple of issue with these Phones.
1) Can I have GUI access of SIP phones ? Like for SCCP phones we can access through GUI.
If there is any document which says it's possible then please share the same.
I am specifically looking for SIP phones. GUI for my SCCP phones are working perfectly fine.
Below is my config for voice register global
mode cme
source-address 10.105.61.2 port 5060
timeouts interdigit 6
max-dn 100
max-pool 100
authenticate register
timezone 35
time-format 24
date-format D/M/Y
voicemail 299
tftp-path flash:
file text
create profile sync 0201584232787866
ntp-server 10.114.80.17 mode directedbroadcast
conference hardware
camera
video
Vishal
07-20-2017 04:42 PM
I have used this process for 9971 SIP phones on CME and it works fine.
https://supportforums.cisco.com/discussion/12342791/enable-web-access-9971-connected-cme
Can you give it a go and see if it works for your 88XX phones?
07-25-2017 06:30 AM
Hello Jonathan,
I am looking for GUI platform for SIP phones which allow me to do changes of speed dials, forward all, etc, features.
Please let me know if you have any idea on the same.
Vishal
08-09-2017 10:44 PM
Hi Vishal,
There is no ability for the CME GUI to configure SIP phones that I am aware of.
