07-25-2017 10:24 AM - edited 07-05-2021 07:24 AM
Documentation for the IW3702 clearly states:
The PoE OUT port is enabled only when the access point is powered over the PWR port. When powered over the PoE IN port, PoE OUT functionality is not supported.
But does this mean that the POE power function is not supported when on POE IN, and does the POE OUT port still function as an ethernet port (without POE). That is, could I attach to a switch? (which doesn't need the POE).
Or is the port just dead when no powered via the PWR port?
Thanks.
Matt
Solved! Go to Solution.
08-03-2017 06:54 PM
With 802.3at PoE-IN, the Gig1(PoE out) port can forward data traffic.
08-03-2017 06:54 PM
