07-26-2017 02:04 AM - edited 03-19-2019 12:39 PM
Hello All,
I have a Cisco 2901 which I have added to CUCM via the gateway section, using a MAC address off of one its live networked ports.
In my Cisco 2901 I have an FXS card which I have also added to call manager, with a port that I have attached a number to out of my call manager directory ready for the device I will be plugging in.
Aside from testing the device on the day, how can I tell that my router has actually connected properly with CUCM? Is there a show command I can do in the CLI of the device? Will my config trickle down from CUCM to the 2901 in regards to voice-ports ect?
Apologies I haven't done any voice courses or work any advice is greatly appreciated.
Solved! Go to Solution.
07-26-2017 02:35 AM
For adding it as SCCP see below.
https://supportforums.cisco.com/document/12450616/stcapp-how-configure-fxs-ports-cucm
For MGCP
https://supportforums.cisco.com/document/90521/mgcp-gateway-integration-cucm-and-pstn-service-provider
http://www.cisco.com/c/en/us/support/docs/voice/media-gateway-control-protocol-mgcp/23966-mgcp-pri-cm.html
https://www.youtube.com/watch?v=-QwICmRqfx4
for H323
https://supportforums.cisco.com/document/99806/adding-h323-gateway
https://www.youtube.com/watch?v=q82qf9HJkyw
for SIP trunk
https://supportforums.cisco.com/blog/12108326/implementing-sip-gateways-cucm
What is the purpose of adding this gateway, what are you trying to achieve.
(Rate if it helps)
JB
07-26-2017 02:26 AM
How are you trying to add this to CUCM, you would have to choose a protocol
MGCP \ H323 \ SIP ?
JB
07-26-2017 02:31 AM
Hello thanks for your response,
The options I have when adding a device are mgcp and sccp, we use sccp
07-26-2017 02:35 AM
For MGCP
for H323
for SIP trunk
(Rate if it helps)
JB
07-26-2017 02:50 AM
Thank-you for your quick responses, this is 100% what I need I believe there is afew commands missing in the router's cli that I hadn't been aware of.
07-26-2017 02:52 AM
Happy to help,
Thanks for updating the post.
JB
