Cisco wlc 2504
samiolo.luca
Hi, I jhave a wlc 2504. I am trying to configure through the gui configurator: i Save the configuration but When i try to Connect with the new IP i cannot: i have tryed to use cli configuraton but i cannot log in with the new ip...seem that not Save correct the new configuration. I use mozilla e Windows 7 to configure the Device. Must i upgrade the firmware? Best regards
Luca
Can you post "show interface detailed management" from WLC and "show run interface x/x" from your switch this WLC connect (x/x is interface connect to wlc)
To see if any firmware upgrade required post "show sysinfo" output from WLC as well
Rasika
I can do it only tomorrow. Have you any suggestions?
Thanks.
Luca
