Slow wifi speed on AIR-CAP1602I-E-K9
AhramSecurity
Hi all
I am having a slow connection on Cisco access points . 10* (AIR-CAP1602I-E-K9. )
on average i get about 4-5 MB/s  Transfer Rate.
Given that all connections between devices is Gigabit.
we have tested the scenario when only one client is connected , and all network is empty (National Vacation day) ,the transfer rate is around 6 MB/s.
Anyone can advise what to check ?  how to resolve and increase speed?
This behavior is for all the access points ? i guess it's not a topology issue ,but more like a configuration issue on WLC 2504?
please assist.
the schema is :
Core Switch (WS-C4503-E) -> Switch SG300-52P-K9-NA -> 3 Access Points (AIR-CAP1602I-E-K9).
Core Switch (WS-C4503-E) -> Switch WS-C2960-24PC-L -> 2 Access Point (AIR-CAP1602I-E-K9)
Core Switch (WS-C4503-E) -> Switch WS-C2960-24PC-L -> 1` Access Point (AIR-CAP1602I-E-K9)
Core Switch (WS-C4503-E) ->Wireless controller (AIR-CT2504-K9)
Total :
1*Core Switch (WS-C4503-E) , Connected to 4 (Switch WS-C2960-24PC-L ) and 1* Switch SG300-52P-K9-NA.+ 1*WLC 2504
The 4*2960 and the 1*SG300  are the ones connected to the 10*1602 Access points.
7 Replies 7
Pls attach "show sysinfo"  and "show wlan  <wlan_id>" output to see how you configure your SSID.
Also let us know about what client you use for this testing. Most of the time wireless performace is limited to client capability. See below site for client capability comparison
clients.mikealbano.com
Rasika
*** Pls rate all useful responses ***
Hi Rasika Nayanajith
kindly find below details.
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.120.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... ASGWLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.111.20
Last Reset....................................... Software reset
System Up Time................................... 4 days 14 hrs 56 mins 39 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... EG  - Egypt
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +23 C
External Temperature............................. +27 C
Fan Status....................................... 4400 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 2
Number of Active Clients......................... 35
Burned-in MAC Address............................ 00:08:2F:11:62:20
Maximum number of APs supported.................. 10
(Cisco Controller) >show wlan  1
WLAN Identifier.................................. 1
Profile Name..................................... WLAN
Network Name (SSID).............................. AHRAM
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
Number of Active Clients......................... 34
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 12 hours
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... ASGWLC
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ wlan
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
--More-- or (q)uit
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
--More-- or (q)uit
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
      Framed IPv6 Acct AVP ...................... Prefix
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
--More-- or (q)uit
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
--More-- or (q)uit
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
   Eap-params.................................... Disabled
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Split Tunnel (Printers).......................... Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
--More-- or (q)uit
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
 Mobility Anchor List
 WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority  Policy Name
Ahram,
Thanks for output.
From the radio policy, I see that we are making use 2.4 radio and channel the client is in 13. Any specific reason why we are not using 1,6,11. Can you please share the supported channels for 2.4 radio profile?
Was this working fine or is it a new set up?
Also below is the output which I am looking for and it ended up showing as unavailable. Can you closely watch one more client which is facing the issue and see if we get an output for this.
     Radio Signal Strength Indicator............ Unavailable
      Signal to Noise Ratio...................... Unavailable
Sreejith
You are running very old code and it could be specific to code you are running. I would upgrade it to 8.2.160.0 code & see if same issue still there. Here is 8.2.160.0 release notes for reference
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82mr6.html
Rasika
I will upgrade the code version next weekend.
i will test after the upgrade then refer back
sremk
Also it would be great if you can share the below output which would tell us what rate the clients are falling under.
show client detail <mac address>
Hi sremk ,
Below a client details for one of the clients,
note: speed issue is for all clients not only this one.
(Cisco Controller) >show client detail FC-F8-AE-62-1A-DD
Client MAC Address............................... fc:f8:ae:62:1a:dd
Client Username ................................. N/A
AP MAC Address................................... 2c:3e:cf:ca:c7:e0
AP Name.......................................... HT_3rd_IT
AP radio slot Id................................. 0
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 1
Hotspot (802.11u)................................ Not Supported
BSSID............................................ 2c:3e:cf:ca:c7:e0
Connected For ................................... 49 secs
Channel.......................................... 13
IP Address....................................... 192.168.106.102
Gateway Address.................................. 192.168.106.254
Netmask.......................................... 255.255.255.0
Association Id................................... 20
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Client CCX version............................... 4
Client E2E version............................... 1
--More-- or (q)uit
QoS Level........................................ Silver
Avg data Rate.................................... 0
Burst data Rate.................................. 0
Avg Real time data Rate.......................... 0
Burst Real Time data Rate........................ 0
802.1P Priority Tag.............................. disabled
CTS Security Group Tag........................... Not Applicable
KTS CAC Capability............................... No
WMM Support...................................... Enabled
  APSD ACs.......................................  BK  BE  VI  VO
Power Save....................................... OFF
Supported Rates.................................. 12.0,18.0,24.0,36.0,48.0,
    ............................................. 54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
Audit Session ID................................. c0a86f140000030e597e523e
AAA Role Type.................................... none
Local Policy Applied............................. none
IPv4 ACL Name.................................... none
FlexConnect ACL Applied Status................... Unavailable
--More-- or (q)uit
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
Layer2 ACL Name.................................. none
Layer2 ACL Applied Status........................ Unavailable
No. of mDNS Services Advertised.................. 0
Policy Type...................................... WPA2
Authentication Key Management.................... PSK
Encryption Cipher................................ CCMP (AES)
Protected Management Frame ...................... No
Management Frame Protection...................... No
EAP Type......................................... Unknown
VLAN............................................. 6
Quarantine VLAN.................................. 0
Access VLAN...................................... 6
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Implemented
      PBCC....................................... Not implemented
--More-- or (q)uit
      Channel Agility............................ Not implemented
      Listen Interval............................ 225
      Fast BSS Transition........................ Not implemented
Client Wifi Direct Capabilities:
      WFD capable................................ No
      Manged WFD capable......................... No
      Cross Connection Capable................... No
      Support Concurrent Operation............... No
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 0
      Number of Bytes Sent....................... 0
      Total Number of Bytes Sent................. 0
      Total Number of Bytes Recv................. 0
      Number of Bytes Sent (last 90s)............ 0
      Number of Bytes Recv (last 90s)............ 0
      Number of Packets Received................. 0
      Number of Packets Sent..................... 0
      Number of Interim-Update Sent.............. 0
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Id Request Msg Failures...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Request Msg Failures......... 0
--More-- or (q)uit
      Number of EAP Key Msg Timeouts............. 0
      Number of EAP Key Msg Failures............. 0
      Number of Data Retries..................... 0
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 0
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of RA Packets Dropped............... 0
      Number of Policy Errors.................... 0
Client Rate Limiting Statistics:
      Number of Data Packets Recieved............ 0
      Number of Data Rx Packets Dropped.......... 0
      Number of Data Bytes Recieved.............. 0
      Number of Data Rx Bytes Dropped............ 0
      Number of Realtime Packets Recieved........ 0
      Number of Realtime Rx Packets Dropped...... 0
      Number of Realtime Bytes Recieved.......... 0
      Number of Realtime Rx Bytes Dropped........ 0
      Number of Data Packets Sent................ 0
      Number of Data Tx Packets Dropped.......... 0
--More-- or (q)uit
      Number of Data Bytes Sent.................. 0
      Number of Data Tx Bytes Dropped............ 0
      Number of Realtime Packets Sent............ 0
      Number of Realtime Tx Packets Dropped...... 0
      Number of Realtime Bytes Sent.............. 0
      Number of Realtime Tx Bytes Dropped........ 0
Nearby AP Statistics:
      HT_3rd_IT(slot 0)
        antenna0: 47 secs ago.................... -61 dBm
        antenna1: 47 secs ago.................... -70 dBm
      HT_2nd_IT(slot 0)
        antenna0: 48 secs ago.................... -61 dBm
        antenna1: 48 secs ago.................... -67 dBm
      HT_1st_HR(slot 0)
        antenna0: 48 secs ago.................... -72 dBm
        antenna1: 48 secs ago.................... -74 dBm
DNS Server details:
      DNS server IP ............................. 192.168.201.1
      DNS server IP ............................. 192.168.201.2
Assisted Roaming Prediction List details:
 Client Dhcp Required:     False
--More-- or (q)uit
Allowed (URL)IP Addresses
(Cisco Controller) >?
