ISE 2.2 Wireless Setup Wizard
I was checking the new Wireless Setup Wizard in ISE 2.2 and it seems very useful. I saw a few videos in youtube about how to run the setup and it is very simple but I have a question since everything seems to indicate that this works fine on new installations of ISE and WLCs.
Can this run on scenarios where ISE and the WLC already has some configuration? In my case ISE is already connected to the AD and the WLC. I already configured the Radius servers in WLC.
Will my existing configuration will cause issues or will it break things?
Deepthi
Hi Paul,
The Beta Config in ISE works with preconfigured AD and WLC. That wouldnt be a problem.
The only problem i faced with authenticating the wireless clients who are on the AD is that the AD name we configured on the "External Identity Resources" and while configuring Wireless Beta version must be same.
Rest of the configuration is the same and work perfectly.
