07-27-2017 10:45 AM - edited 03-14-2019 05:28 PM
Hello, I'm trying to set the estimated wait time in studio to speak back to the caller. Right now I am just hard coding a value in ToExtVxml[1] as "ewt=100;".
I can see in the activity log that the parameter ewt=100 is in the log. What I want to do next is to use say it smart to play back the number to the caller in an audio element, then play the prerecorded "minutes.wav".
I am using an app modifier to gather the data and storing it as element data, value is {Data.Session.ewt}
From there I move to an audio element and the data being {Data.Element.set_EWT.ewt} and would like to use the say it smart to play that number.
In the error log I see the following error. I must be setting it wrong but not sure where.
Audio_01,element,warning,A substitution representing Element data from element "CVP Subdialog Start_01" and variable named "ewt" referred to non-existent information. An empty string was substituted instead.
Solved! Go to Solution.
07-27-2017 12:23 PM
You don't need to "move" it. You have the data as a session variable - Data.Session.ewt. Just give that to the Say It Smart element (with substitution, of course).
Geoff
07-27-2017 12:23 PM
Geoff
07-27-2017 01:47 PM
Thanks Geoff.
I also had my say it smart audio path wrong... I was in the app directory instead I changed it to http://mediaserver/en-us/sys
Worked after the change.
