Hello everyone,
We have an odd issue with a pair of N3K switches, model N3K-C3064PQ-10GX and GLC-T tranceivers.
The tranceivers are properly detected and original Cisco, added in port 43 and below are the results. We tried speed 1000 and speed 100 and no negociate auto and so on, nothing seems to work. Cables are CAT6
Any advise would pe appreciated
Ethernet1/43
transceiver is present
type is 1000base-T
name is CISCO-FINISAR
part number is GLC-T
revision is A
serial number is AGM174625W7
nominal bitrate is 1300 MBit/sec
Link length supported for copper is 100 m
cisco id is 3
cisco extended id number is 4
DOM is not supported
Then
Ethernet1/43 is down (Link not connected)
admin state is up, Dedicated Interface
Hardware: 100/1000/10000 Ethernet, address: e865.49ed.befc (bia e865.49ed.bed2)
Internet Address is 10.64.128.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
auto-duplex, 1000 Mb/s, media type is 1G
Beacon is turned off
Auto-Negotiation is turned off, FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
Last link flapped never
0 interface resets
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
0 jumbo packets 0 storm suppression packets
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
then
version 7.0(3)I4(6)
interface Ethernet1/43
speed 1000
no negotiate auto
