08-03-2017 12:50 PM - edited 07-05-2021 07:29 AM
we have a Wireless AP 3702 has PD ports but is varying in its PoE draw. sometimes it draws 16.8W, sometimes 15.4W. We have it connected to a PoE injector that can provide 30W. it works in the lab but not in the actual network. is anyone else having this happen? any ideas?
Solved! Go to Solution.
08-17-2017 03:36 PM
08-03-2017 02:35 PM
What is the model of the switch and the IOS version of the switch?
Is CDP enabled?
What version of code is the AP/WLC running on?
08-03-2017 02:38 PM
waiting for those answers, had sent those to the customer this morning. also asked for some basic info on the LED status.
08-04-2017 08:52 AM
more information:
We re running 8.0.140.16
LED turns Green around 2 sec in both lab and actual network
IP address of AP is static
All LED are Green
08-04-2017 09:29 AM
also, the product that provides PoE+ is a simple media converter. transparent product.has two PoE+ ports, each providing 25.5W
08-07-2017 07:44 AM
CDP is being used. Do you have any ideas? our customer is getting frustrated. thanks
08-07-2017 06:11 PM
Firmware is a special engineering release. It's also hard to troubleshoot since the AP is powered up using an injector.
08-14-2017 10:20 AM
Are you stating that there is a fw release for the customer to update his AP and this may resolve it?
08-14-2017 01:42 PM
No, what I meant was the number of factors affecting the AP's current behaviour multiplies because of the power injector and the firmware version.
You might want to run a TDR on the cables as a start.
08-14-2017 02:42 PM
ah! I see....will pass that along. thanks.
08-17-2017 08:09 AM
I had told the customer I felt there was some kind of interference in the actual application, because in the bench test, all the products worked fine. Well, he indeed found that there is a problem with the Ethernet cabling in the application. So case closed!!! THANKS
08-17-2017 03:36 PM
Thanks for the update.
Please mark this thread as "Answered".
