Need urgent help on ip device tracking max command
Aug 12th, 2017
Hi ,
I need urgent help, I have installed 30  3650 devices in client location
I want to run ip device tracking max 0 command on cisco 3650 switches but I think its not supported , if any one can suggest if any alternate for this command which we can run on 3650 Switches
Philip D'Ath Sat, 08/12/2017 - 15:24
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN, LAN, VPN
Are you wanting to disable device tracking?
neeraj.a.verma Sun, 08/13/2017 - 00:07
Hi Phlip ,
This command also not supporting on 3650-FQM  at interface level - software verion 16.3.3, please suggest
Philip D'Ath Sun, 08/13/2017 - 12:18
    2017 WAN, LAN, VPN
I would not run 16.x code unless you really have to.  It is very new.  I would stick to the more mature 3.7 or 3.6 train.
Leo Laohoo Sun, 08/13/2017 - 15:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
He doesn't have a choice, Philip.  FQM requires a minimum of 16.3.1.
Bad luck, I guess.
Philip D'Ath Sat, 08/12/2017 - 15:25
    2017 WAN, LAN, VPN
If you want to disable it I think the command is something like "nmsp attachment suppress".  I think this might have to be applied at the interface level.
Leo Laohoo Sun, 08/13/2017 - 15:34
  • Hall of Fame,
    2017 LAN, Wireless
IP Device Tracking needs to be enabled globally and at the interface level.
The minimum lines of configuration needed are the following:
  1. Globaly:  ip device tracking
  2. Interface-level:  ip device tracking max <ANY NUMBER HIGHER THAN 0>
To disable IP Device Tracking, use the global command "no ip device tracking" and remove the interface-level command.
