How to forward voicemail to another mailbox?
Huddles18
I've found some articles about this, but haven't really found something that's really up-to-date.
I am currently running UC 10.5.
We have a user, UserA, that has left our organization. The manager, UserB, is requesting to have UserA's extension and voicemail transferred to their extension/mailbox. Forwarding the calls was easier said than done, but I am having issues with finding a way to forward the voicemail.
In UC, I have removed UserA's mailbox and created a Call Handler with UserA's old extension (341).
Next, under caller input, I gave option 1 to transfer the call to UserB's mailbox:
Everything else is pretty much at default for our system. When I tried to call the old extension, it will transfer my call to UserB, but when it reaches this call handler, it will ask for an extension and then immediately say "GoodBye" and hangup. Even when I do input 1, it would say that it is the wrong extension.
I have also tried to change the transfer rules on both the "Standard" and "Closed" to transfer it to UserB's extension, but I am still getting the same result.
What am I missing? Any help would be greatly appreciated.
Rob Huffman
Hi there,
The easiest way to do this is to use Alternate Extensions in Unity Connection. Let's set up an example;
User A - who has left the company is at DN 2000 and the Manager User B is at DN 5555.
Take out/delete the mailbox at 2000
Set the call forward all on 2000 to go to 5555 (as you have done)
On the User B mailbox at 5555 add 2000 as an Alternate extension in Unity Connection -- User(x5555)---Edit---Alternate Extensions---Add New x2000
This should do exactly what you are looking to accomplish
Cheers!
Rob
Rob Huffman
Hi there,
Cheers!
Rob
Man, that was a lot easier than I thought it was! Perfect! Thanks for the help, Rob!
Rob Huffman
Hi there,
You are most welcome!
Cheers!
Rob
