TMS database string
SQL Admin needs to move my TMS database to a new server. Does anyone know where in the TMS application where I can modify the connection string that reaches the database? I've searched TMS every menu and can't locate it.
navidsyed
Darrell,
DB Server information can be updated once you login to the physical Windows Box & then launch TMS Tools to update the DB Server information.
You'll use TMS Tools, log into the server where TMS is installed and it's located in the Start Menu, you can then change the database connection information under the Configuration tab of TMS Tools.
