Warning message
fax boards
Jul 11th, 2000
  • Bronze, 100 points or more
Can I use any fax board supported by LightningFax in the Unity server? We want to use a DID card from Brooktrout that's not on the supported list.<br><br>
Anonymous (not verified) Fri, 07/14/2000 - 08:34
Unfortunately, no. The product configuration document lists all the GammaFax cards on it and these are the only ones you can run on the box with Unity. Some of the Brooktrout cards didn't "play nice" in the Unity box with our other voice cards (Dialogic and NMS) so we had to exclude them.
That said, in Unity 2.4 you can run ActiveFax in a two box configuration and so long as the fax server is not on the same box with the voice cards, you can install any card supported by Interstar. AV doesn't stock these cards but you can get them on your own.
Jeff Lindborg
Unity Product Architect
Active Voice Corp
[email protected]
