Warning message
no MWI on 7960
Dec 21st, 2000
We have CM 3.05a with Unity 2.4 (build 2.4.5.66) and 7960 phones. We can't get the Message Waiting light to go on after a message is left on the Unity server. We have checked the CM > Service > Service Param > Cisco Call Manager > Param MessageWaitingOffDN and ...OnDN and both #'s match the Unity settings. We can even dial up the #'s with the phone and get the MWI to go on and off manually.
Thanks.
brad.swanson Thu, 12/21/2000 - 11:36
Thanks. I did look at the url. We are using Unity and I did confirm the DN's are different for On and Off. I can actually dial up --- with my IP Phone ---the OnDN # and turn the MWI on, then dial up the OffDN # and turn it off, but for some reason Unity is not able to talk to the CM and do it for Voice Mail (the Unity server can ping the CM ;) ). I tried deleting the DN's for the Unity, booting the server, adding the DN's back in...no luck. Also, when I log into VIewMail I see the message on the Unity server. hmmmm...????
pieter.bos Thu, 03/22/2001 - 15:35
Brad
I also battled a long time with the MWI and Unity. In the end my problem was partitions. It looks like the MWI for Unity is in the partition. I still don't know how to change that, but if you put the phone/line also in the partition the MWI works.
It was a bit different with UOne, because there we had a MWI port under the UOne device. It was possible to assign a partition for the MWI.
Hope this helps
Pieter
