Warning message
vpn problem
Jan 16th, 2001
i need config a link between a vpnclient via dial-up to internet and a 1750. but the negotiation dont to pass, the log view of vpn client show the follow error:
"IreIKE: unable to acquiere CAPI provider handle (80090020)!"
I dont use a ISDN connection.
jbohla Mon, 01/22/2001 - 15:00
I’d start off by uninstalling and reinstalling the VPN Client. I’ve run into this problem before and it’s usually a bad install or the installer didn’t clean up properly. Be sure to reboot in between the uninstall and reinstall. Also make sure you’re on Win 98 because client 1.1 doesn’t work on W2K or ME.
