01-17-2001 01:50 AM - edited 03-12-2019 11:01 AM
Has anybody had any experience in configuring a transparent CCS link via Cisco routers to link two Lucent Definity PABXs?
Thank you.
01-19-2001 06:18 AM
I connect two Definity via two routers cisco2611 (1 serial, HDV-1E1-30)
01-22-2001 02:23 AM
Thanks for the response.
Did you set up a CAS link of a CCS? I have succesfully set up a CAS link but I need to have CLI coming over the link as well.
CCS doesnt seem as straight forward as CAS.
Thanks again.
02-05-2001 11:48 PM
I'm not the telecom guy in our group, but I'll try to get him to through some info into this for you. We currently have 6 Definity systems (5 prologix, 1 g3) connected together via an IP/FR network. We have implemented 5 digit dialing, interoffice voicemail messaging, etc. I don't know exactly what the link is, but I'll see if he can help.
02-06-2001 06:49 AM
The Definity switches are connected to Pollable Storage Units that buffer the CDR data over a serial link. The PSUs are connected to Tektronics/Avaya MSS-100 IP Interface that connects to the PSU withy another serial cable. The CAS XP (Veramark/MOSCOM) software initiates an on-demand download to the PSU through the MSS-100 which supplies the IP connectivity. This is the official Avaya solution. I suppose you could connect the MSS-100 without the PSU and try to stream the CDR data but if you lose your WAN, you lose the data but are protected with a PSU. Let us know your thoughts! abellak's telecom guy
02-11-2001 06:21 PM
here's a write up on configuring ccs with 3810 routers
