Warning message
W2K-Build-In Client VPN Connection with C3620
Feb 26th, 2001
Hello Everbody!
Has one of you already tried to set up a VPN Connection between the Windwows 2000 IPSec-Client and a Cisco 3620 Router running IOS Ver. 12.1.5?
I do have some problems! ISAKMP is working well but the IPSec SA is not being set up!
Might be the wrong IPSec-Transform-Set ? (esp-des esp-md5-hmac).
Does anyone have a clue for me ?
Thanks!
Mike
thomas.chen Thu, 03/01/2001 - 15:03
  • Silver, 250 points or more
After reading your post it looks like you’ll need the new Windows 2000 VPN Client from Cisco. I read another post that says it should be out sometime in March. Does anyone know if the built-in client in Windows works?
michael.gessner Mon, 03/05/2001 - 03:09
Dear Thomas!
I found a solution for the built in IPSec-Client.
With great help from Yoshua McCloud /Cisco!
If you need the config, send me your e-mail address and I can mail it to you!
Mike
tawye Fri, 03/02/2001 - 02:52
Hi, I got this working (IPSEC DEC) on 12.1.6 without problem. Could not get it to work with L2TP at the same time though.
Is NAT being performed anywhere ? If so this will cause problems. You could try using the transform ESP-DES without any MD5-Hash.
Also check what the Windows 2000 error log shows in mmc/computer management/system tools/event viewer/system.
